that would be a weak pump or a blocked pipe not giving you the flow to the hp pump so fix that, then keep going with the rest if replacing the pipe work dose not fix it.
did you take the pipe with the whit clip off as i got the feed and return mixed up
406 HDI GLOW PLUG RELAY
Re: 406 HDI GLOW PLUG RELAY
Yeah, was a white clip on the right side of the bowl as you look at it. I had the head of the filter off and watched it fill the bowl up as the ignition was switched.
http://s1182.beta.photobucket.com/user/ ... sort=3&o=0
the item circled in red should be plugged in and the plug is red
It was plugged in when i was trying to start it, unclipped it so i could get access to the injector pipes and injectors to test them.
I am gonna see if i can whip the loom out tomorrow and see any obvious faults along there???
Thanks for all your help so far.
