great for PP and Galetto,
there are several things you have to know while flashing.
Feel free to contact me when you get there...
PP is little bit clumsy for use, but when you get used to it it works good.
br
Replacing 5 gear Transmission with 6 gear Transmission
- srdan
Re: Replacing 5 gear Transmission with 6 gear Transmission
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- IDLE SPEED OPTIMIZED (835 RPM)
- PRO TUNED
- LOOKING FOR 6 GEAR ML6C (CITROEN C5 2.2 HDI YEAR 2001-2003) TRANSMISSION ...
- DE-FAPPED
- EGR OFF
- PRO TUNED
- OdinEidolon
will do, thanks!srdan wrote:great for PP and Galetto,
br
Hi srdan and Odin
Any further progress on the quest for 6speed transplant?
I keep looking for C5 2,2 HDI 6speed 2001 -2003 on ebay but still not seen one.
saw This for a 406. http://www.ebay.co.uk/itm/407-2-0-HDI-R ... 230eb8eb8f
Is that what you say is totally different?
Under the speedo blank cover is there gear teeth to drive the speedo, or did they delete teh machining?
My 5 speed synchomech on 3 and 4 is failing and I want to change the box. Would be really cool if I can drop in a 6speed.
Regards
Regards
- OdinEidolon
Hi, you'll need a 6 speed ML6T (if yours is a ML5T) from the same engine, which is code 4HX. This means getting it either from a 607 2.2HDi 136 or a C5 2.2HDi 136. I do not think any other gearbox will fit without major modifications.6speedmanual wrote:Hi srdan and Odin
Regards
