1999 406 GLX estate Clutch problem
Posted: Tue Mar 09, 2010 11:56 am
by Mellers
Hi all. I've just bought my first 406 and I love it. It's a 1999 on a T, 2.0 GLX Estate. My only real concern at the moment is that it is difficult to pull away smoothly because the clutch feels juddery as I lift it. Once away it's fine and doesn't seem to be slipping. The release is quite near the top and it seems to get worse the longer the run. It is less noticable when I first start up and pull away.
Any advice please?
Cheers,
Mel
8)
Re: 1999 406 GLX estate Clutch problem
Posted: Tue Mar 09, 2010 12:37 pm
Sounds like the classic worn Dual Mass Flywheel. Tell-tale signs are also a sharp squeek when you start the engine and a squeek/chatter as you bring the clutch in and out.
Mine was the same year/engine and did this for 3 years and was even slipping after an hours' run. You can learn to live with it, or replace the lower rear engine mount helps quite a bit, or do that and replace the clutch assembly with a solid flywheel conversion.
A proper DMF/clutch job will probably be around £600.00 :cry:
A 'conversion' perhaps £450.00?? others may be able to confirm.
The 406 clutch is a laour intensive job but, as I said, you may well be able to live with it for the time being.
In case you didn't know the DMF was fitted by Peugeot (and most manufacturers now) to dampern the rough nature of the diesel engine to reduce vibration through the drive train (which conversely it ends up creating anyway :roll: )
Welcome btw.
Posted: Tue Mar 09, 2010 12:44 pm
by Doggy
Hello & Welcome 8)
Which engine is yours?
Posted: Tue Mar 09, 2010 12:49 pm
Oops, I never thought to ask what engine - just assumed it was an HDi, here's hoping I was right........
Posted: Tue Mar 09, 2010 1:27 pm
by puggy
:arrowu: :arrowu: :arrowu: i'm waiting with fingers crossed primed and ready
for the answer welly :twisted: :twisted: :twisted:
Posted: Tue Mar 09, 2010 1:56 pm
puggy wrote::arrowu: :arrowu: :arrowu: i'm waiting with fingers crossed primed and ready
Says the man with the newest, cleanest, shiny'est clutch on here :mrgreen:
Posted: Tue Mar 09, 2010 3:13 pm
by Mellers
Sorry, it's 2.0 Petrol engine.
8)
Posted: Tue Mar 09, 2010 9:51 pm
by DaiRees
Can't remember if that had a cable or hydraulic clutch? If it's a cable, it's probably the cable that's your culprit. :o
Posted: Tue Mar 09, 2010 10:01 pm
Or oil on the clutch plate or a broken engine mount :?
Posted: Wed Mar 10, 2010 9:47 am
by mjb
steve_earwig wrote:or a broken engine mount :?
Usually the cause on mine... I'll be more specific and suggest the top (pear-shaped) mount, £20 or so
Posted: Wed Mar 10, 2010 10:28 am
by puggy
Welly wrote:Oops, I never thought to ask what engine - just assumed it was an HDi, here's hoping I was right........
Bit premature there Welly :P Do i remember Mrs Welly mentioning something along those lines :twisted: :twisted:
Posted: Wed Mar 10, 2010 10:39 am
I know, all that stuff I typed - and for nothing :( and I can't help with the petrol clutch either :roll:
And there's nothing wrong with being 'quick' - it's not what you do with it it's how quick you..err wait...it's not how small it is it's the...err...bugger :|
Posted: Wed Mar 10, 2010 11:53 am
by puggy
:arrowu: :arrowu: :arrowu: he he he he heeeeee !!!!
Posted: Mon Mar 15, 2010 2:47 pm
by gumby6371
Just changed my clutch cable yesterday on my 97 1.9td GLX due to juddering while pulling away and it's like driving a new car !
Pretty easy to do if you have an axle stand 3 hands and very flexible arms (I got wedged in the footwell trying to hook the new cable on to the pedal :cheesy: )
If yours is cable not hydraulic I'd give it a try before you spend big money
