Evening All
Having a bit of a braking problem with my car, firstly the ABS light comes on and says abs fault on the screen in the centre console also sometimes i get a brake judder almost like worn brakes even though they are not and today on the way home i was driving on the motorway and had to brake hard but my brakes wouldnt have it and nearly didnt stop it was almost as if the pedal was pushing back at me. Any help would be greatly appreciated.
Adam
ABS Fault And Braking Issue
Re: ABS Fault And Braking Issue
sounds like you might have a fault with the master cylinder not giving enough force then giving to much so the abs backs it off
whats the fluid like? any crap in the master cylinder?
My Xantia did this when I had an intermittent fault with a sensor.
Your symptoms sound identical to what I was suffering.
Unplugged the ABS controller and all was well again.
I never found out which sensor was at fault though as I stuck the car into a field not long after (ABS wouldn't have helped there)
Cheers
Steve
Cheers
Steve
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
Hi
The brake fluid level is fine but scared the sh1t into me today i was on the A1 doing 80 and felt like i had nobrakes which is the abs sensor plug the brakes are fine but make noises like they are worn though all were replaced at different times last year
How about if you pull the fuse on the ABS? I'm thinking wheel sensor too.
Sounds like totally unrelated problems both on the braking system, if you pedal is going hard and feeling like there is nothing there you have a servo problem, try and apply the brake gently and see if there is anything there and then slam the brakes on and see if they go hard strait away, then you have a vacuum problem. as for the abs fault a 30-40 pound diagnostic at any capable garage will let you know which sensor is playing up on the car. Not worth the risk having unadequate brakes on the car, no matter how much it costs.
it seems like the fault weve had on me daughters corsa she nearly went into the back of someone, on inspection i found that the abs sensor ring was cracked, only 25 squid inc the joint
