clutch pedal height
keithmorris68
clutch pedal height
Post by keithmorris68 »
Hi everyone, just wondered if anyone could give me some advice, ive got a 1999 hdi (90) & the clutch pedal sits about an inch or more above the brake pedal, the clutch works & operates fine, but this problem is causing me to ride the clutch ( not good i know) i guess i just wondered if there was an adjustment anywhere for it?
kind regards
Keith
barryj75
Re: clutch pedal height
Post by barryj75 »
dont know if its a common prob mines the same had re con box and new clutch last year and just changed clutch and brake fluid and stiil the same i take my foot clean off the pedle every change so i dont ride it but might be a fault in another part of the system
Japster
Post by Japster »
And my 406 is exactly the same, as before take foot off the pedal to stop it being ridden
jasper5
Post by jasper5 »
Some cars have a rubber bung on the end of a screw to adjust the pedal height, if the 406 doesn't have this try fitting something to the pedal to reduce the height....look at where the pedal rests onto and fit some sort of rubber bung over the pedal to make it sit lower, just be careful that you leave some slack so that the clutch is not being operated by the pedal being pushed down too much.
barryj75
Post by barryj75 »
im going to have a look at my peddle in th morning let you know if it can be done on mine
barryj75
Post by barryj75 »
well ive had a look today and cant do anything with the peddle. drove my sister in laws 2006 307 1.6s today and thats the same and only got just over 20000 miles on it so if anyone has solved this please let me know :wink:
