How easy should a rear wheel bearing spin??Car has 120k now,but the wheel bearing wont turn freely,ie you cant spin it by hand,it just keeps stopping.There was no play in it with the wheel on,but i have been getting a noise from it(l/h side),& there is a slight grinding noise when turning the brearing.
I think i will change it anyway,as i`ve got to bolt through the handbrake shoes as 1 retainer & spring has come off & chipped the abs ring.ABS still working though,so i think i`ve caught it in time this time,unlike the r/h side last year
Rear wheel bearings can't be changed on there own
You have to buy a complete hub, so that will sort out your chipped ABS ring out.
Just make sure you order the right one, as I ended up with ABS warning light, as my car is a 99, but a D8, and the motor factors sold me a hub for a 99, but wasn't right, and ended up in the end, having to take the hub back off, and returning for exchange of the correct one.
1999 D8.5 HDi GLX - Sold
2007 Mondingo Zetec - I seek forgiveness Bring back my 406
It could be that the handbrake shoe retainer missing is causing the backplate to be hitting the disc, therefore making the grinding noise and the wheel to turn with difficulty.The shoe could also be out of place due to the missing retainer.
To test the bearing properly you need to remove the disc and caliper and fit the wheel back on so that the bearing can spin freely.
Yes, you need to check the ABS ring some have 29 teeth some have 40 odd.
All rear brake assy removed before checking.The rear shoes were rubbing a bit,as well as some rust on the backplate.
Think i will fit another bearing/hub.£59+vat from ECP.£5 more than last aug when i did the r/h/side.
As said,its all dissmantaled,& having done the other side last year,its now a 10 min job to remove & refit a new hub.Things are better when you have a 3/4"drive socket set for the hub nut
Will just pop the wheel on in the morning & see how that spins though
Thanks guys
Well,all done now,another easy fix.No more noise.Pulling the old hub off,it came apart,but the ball bearings were very scored/worn.
Only trouble was,i put the hub,hand brake shoes,disc back on,only to find the 2 handbrake shoes retaining springs left over DO`H
On another note,the back plate now has a rust hole in it.I`ve not made any calls yet,but can these be gotton hold of??
Mine aren't, not that I plan to put it in any breaker's yards, but it must be possible to find some decent ones. The only problem is how much of the suspension they'd want to sell you and how much it would cost.
hammerman wrote:All rear brake assy removed before checking.The rear shoes were rubbing a bit,as well as some rust on the backplate.
Thanks guys
So,i did the r/h/side wheel bearing/hub in aug 2009.Its now december 2014,and the r/h/side is shot.Hell of a noise after a few mins on the motorway.Time to replace again.
hammerman wrote:Things are better when you have a 3/4"drive socket set for the hub nut
And what have i done this time???Forgot to bring my big socket set home from work Stripped it all down,brakes,caliper etc,and no means of undoing hub nut.Stoopid me
