Rear wheel bearing
Posted: Mon Mar 29, 2010 7:25 pm
by hammerman
How easy should a rear wheel bearing spin??Car has 120k now,but the wheel bearing wont turn freely,ie you cant spin it by hand,it just keeps stopping.There was no play in it with the wheel on,but i have been getting a noise from it(l/h side),& there is a slight grinding noise when turning the brearing.
I think i will change it anyway,as i`ve got to bolt through the handbrake shoes as 1 retainer & spring has come off :roll: & chipped the abs ring.ABS still working though,so i think i`ve caught it in time this time,unlike the r/h side last year :roll: :cry:
Re: Rear wheel bearing
Posted: Mon Mar 29, 2010 9:14 pm
by plod
Rear wheel bearings can't be changed on there own
You have to buy a complete hub, so that will sort out your chipped ABS ring out.
Just make sure you order the right one, as I ended up with ABS warning light, as my car is a 99, but a D8, and the motor factors sold me a hub for a 99, but wasn't right, and ended up in the end, having to take the hub back off, and returning for exchange of the correct one.
Posted: Mon Mar 29, 2010 9:45 pm
by jasper5
It could be that the handbrake shoe retainer missing is causing the backplate to be hitting the disc, therefore making the grinding noise and the wheel to turn with difficulty.The shoe could also be out of place due to the missing retainer.
To test the bearing properly you need to remove the disc and caliper and fit the wheel back on so that the bearing can spin freely.
Yes, you need to check the ABS ring some have 29 teeth some have 40 odd.
Posted: Mon Mar 29, 2010 11:08 pm
by hammerman
All rear brake assy removed before checking.The rear shoes were rubbing a bit,as well as some rust on the backplate.
Think i will fit another bearing/hub.£59+vat from ECP.£5 more than last aug when i did the r/h/side.
As said,its all dissmantaled,& having done the other side last year,its now a 10 min job to remove & refit a new hub.Things are better when you have a 3/4"drive socket set for the hub nut :cheesy:
Will just pop the wheel on in the morning & see how that spins though :oops:
Thanks guys :)
Posted: Wed Mar 31, 2010 8:51 am
by hammerman
Well,all done now,another easy fix.No more noise.Pulling the old hub off,it came apart,but the ball bearings were very scored/worn.
Only trouble was,i put the hub,hand brake shoes,disc back on,only to find the 2 handbrake shoes retaining springs left over :oops: :roll: DO`H :cheesy:
On another note,the back plate now has a rust hole in it.I`ve not made any calls yet,but can these be gotton hold of?? :)
Posted: Wed Mar 31, 2010 1:04 pm
by mjb
hammerman wrote:On another note,the back plate now has a rust hole in it.I`ve not made any calls yet,but can these be gotton hold of?? :)
£90 each from dealers :cry:
Posted: Wed Mar 31, 2010 1:20 pm
Did you try Ade for some? I think most breakers will be wanting to sell the whole assembly :(
This place is selling them for 70€ incl. German sales tax, looks like that's still cheaper with the postage (might even loose the tax if it's export).
Still ridiculously expensive for a bit of tin :frown:
Posted: Thu Apr 01, 2010 9:21 am
by mjb
I suspect breakers yard backplates would be just as bad...
Posted: Thu Apr 01, 2010 9:36 am
Mine aren't, not that I plan to put it in any breaker's yards, but it must be possible to find some decent ones. The only problem is how much of the suspension they'd want to sell you and how much it would cost.
Posted: Thu Dec 04, 2014 9:27 pm
by hammerman
hammerman wrote:All rear brake assy removed before checking.The rear shoes were rubbing a bit,as well as some rust on the backplate.
Thanks guys :)
So,i did the r/h/side wheel bearing/hub in aug 2009.Its now december 2014,and the r/h/side is shot.Hell of a noise after a few mins on the motorway.Time to replace again.
Posted: Sat Dec 13, 2014 12:28 pm
by hammerman
hammerman wrote:Things are better when you have a 3/4"drive socket set for the hub nut :cheesy:
And what have i done this time???Forgot to bring my big socket set home from work :roll: :oops: :roll: :oops: Stripped it all down,brakes,caliper etc,and no means of undoing hub nut.Stoopid me :lol:
