Engine Code
Posted: Mon Apr 12, 2010 11:47 am
by SteveinSpain
hi there can someone tell me where to find the engine code as I dont know how to tell if it is a RHY or RHZ engine as it may have been changed by a previous owner. Thanks Steve in Spain
Re: Engine Code
Posted: Mon Apr 12, 2010 7:14 pm
by DiscoPol
Hi Steve and welcome
if you want to either pm me your vin or post it up i can have a look on servicepox for you if you want bud.
Re: Engine Code
Posted: Mon Apr 12, 2010 7:22 pm
Not much point if the engine's been changed
Excuse my rudeness, hi there Steve
Re: Engine Code
Posted: Mon Apr 12, 2010 7:48 pm
by teamster1975
Welcome in Steve!
Whereabouts in Spain are you? My parents live in Javea on the Costa Blanca
Re: Engine Code
Posted: Mon Apr 12, 2010 7:59 pm
by DiscoPol
But it will let him know what was originally there and therefore whether its been changed, just trying to help like
I used to live in Mijas for a couple of years then moved up to Alicante for my sins, where abouts are you bud
* I sound like im on the blob, sorry
Re: Engine Code
Posted: Tue Apr 13, 2010 6:34 pm
by SteveinSpain
hi im in Murcia and am still looking form help on this topic
Steve in Spain
Re: Engine Code
Posted: Tue Apr 13, 2010 7:30 pm
I'm afraid I've left my Haynes at home, I just had a quick squint under the bonnet but there's so much codswallop in front of the engine I can't see anything. As far as I know, the RHY and RHZ are so similar it's not worth bothering. I'm looking in Pug's own parts catalogued and having trouble seeing any differences in part numbers - same block, head, cam... There seems to be some difference between Siemen's and Bosch but I'll be blowed if I can see what it is.
What sort of concerns do you have?
Re: Engine Code
Posted: Wed Apr 14, 2010 5:27 am
by SteveinSpain
My biggest problem is my car needs a new clutch and apparently they are different depending on which engine is fitted, and as i will be ordering from the uk (as clutch kits there are less than half the price in Spain), it is important that i get the correct one first time so i dont have to mess about trying to return the kit and order a new one.
Any help anyone can give would be greatly appreciated.
Re: Engine Code
Posted: Wed Apr 14, 2010 8:29 am
Aha! I think you should be asking which flywheel you have
Or, seeing as how the different flywheels
should relate to different gearboxes, which gearbox you have...
DW10TD (RHY) BE4R
DW10ATED (RHZ) ML5
I think that's the best way of doing it. There's always the possibility someone's managed to cram a solid flywheel for a RHY into an ML5 but if that much messing around's been done then all bets are off and the only real way of knowing is to take it to bits to find out (and be without a car for a couple of weeks
