turbo problems
Posted: Mon Apr 12, 2010 2:13 pm
by lawsys406t
hi all got a turbo prob i think. its only running 0.5 bar should be 0.9 max and for some reason there is a squeal noise like a fooked belt when under full boost but only after 5.000 rpm in 3rd onwards and the dump valve also changes noise. please help :shock: :( :?:
Re: turbo problems
Posted: Mon Apr 12, 2010 2:28 pm
by FlySpeck
sounds like a boost leak in the cooler pipework, you dont say what engine you have, petrol diesel etc?
It could be a dodgey leaking wastegate too, that makes a screaming noise....
Re: turbo problems
Posted: Mon Apr 12, 2010 3:06 pm
by lawsys406t
its petrol 2.0 8v sri remapped dump valve ect.
Re: turbo problems
Posted: Tue Apr 13, 2010 12:14 am
by FlySpeck
id get it pressure tested for a boost leak then mate, sounds likely unless the turbo bearing is buggered?
