Someone filled up my car for me
Posted: Sat Apr 24, 2010 2:22 pm
by Captain Jack
Hello,
This morning I got into my car and noticed that my fuel gauge was I reading an almost full tank reading. Not quite full but within the "full" zone. Yesterday evening, it was 3/4's full! Is this the dreaded lift pump fault? I tried banging the rear seat in hope that it would un-stick something but it didn't do anything. The trip computer is saying that I have 590 miles to go till empty, which sounds about right for a nearly full tank for me (so far, London driving is averaging at 29mpg). So I guess it's not the dashboard that's playing up as the tip computer agrees with it...
Anything I can check before I start removing the seat etc. to get to the lift pump?
CJ
Re: Someone filled up my car for me
Posted: Sat Apr 24, 2010 7:23 pm
by DaiRees
D'ya know what I'd do Cap'n? Ignore it and leave it alone until it happens at least a few more times. Could just be a gremlin :wink:
Posted: Sat Apr 24, 2010 7:33 pm
by puggy
changes in temperature can have an effect , gas and liquids expand
and contract according to temperature . In summer on the odd hot
day we get if my car has been standing in the sun when i go to it
it quite often reads slightly higher than when i parked it up :shock:
Posted: Sat Apr 24, 2010 7:51 pm
Perhaps it's the same person that fills mine up to half way when I was expecting to need to fill up...
Nothing to do with the lift pump, other than the fuel level sender is part of it :(
Posted: Sun Apr 25, 2010 3:33 pm
by neildavies
Happens with mine occaisionally. You'll need to fill the car up past where it's stuck and that should sort it.
Posted: Sun Apr 25, 2010 6:48 pm
by Captain Jack
Been out today and it's still the same but gone down slightly with usage. Reading around 1/4 tank higher than it should. Will fill it up when I get paid so we'll see if that sorts it!
Thanks guys.
Posted: Sun Apr 25, 2010 9:12 pm
by stevenlizuk
Could be the bad solder on the posts issue that's been on here in the past.
Mine is needing re-soldered and is reading erratically again.
Check for posts relating to dodgy speedos or tachos and the fix is the same.
I did a "how to" ages ago so if you search my postings it should still be in among them.
Hope that helps
Steve
Posted: Mon Apr 26, 2010 7:30 am
This happened to the Volvo a couple of weeks ago. I sloshed in £15.00 (could only get 95 ron from the place :roll: ) then I parked up for 20 mins and upon my return I had a full tank :?
Took ages for it to settle back down and then it just went back to normal :?
Posted: Mon Apr 26, 2010 10:00 am
by lofty
Its another 406 trait im afraid. Im used to it by now, even though it can be mildly irritating
Posted: Mon Apr 26, 2010 7:00 pm
by plod
Gotta agree, mine is all over the place
