Page 1 of 2
EGR Suprise!
Posted: Mon Apr 26, 2010 5:30 pm
by johnboy
Hi all,
Ive just been attempting to take off my EGR valve from my 2002 406 HPI as it failed mot on emissions!
On taking apart ive noticed its been blanked off before?! what i would like to know is if i take out the metal blank plate so as it functions as it should, would this in theory now pass mot? im desperate and need help as im lost without my car :(
thanks
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 5:39 pm
Depends why it was blanked. You could always remove it and see if it helps.
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 5:42 pm
by johnboy
I know! thats what im wondering? i dont know what damage it would have done being blanked?
ill cut out the metal plate and put it backtogether see what happens?
worth a shot!
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 6:12 pm
by mk1rs
go to local car shop and get a bottle of diesel treatment m8
our v plate hdi failed on emisions put a bottle of treatment in and it passed no bother
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 6:33 pm
by DaiRees
Nah don't do that John, maybe petrol treatment would be better? :lol: :lol:
Don't know how to test if it's working unfortunately, might be worth giving it a clean with carb cleaner? Praps someone blanked it off 'cos they thought it was knackered when it was just dirty. If you find out how to test it let us know, also can you take some pics of what you're doing, I've a feeling it'll come in handy one day! :oops:
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 7:21 pm
by johnboy
Ok update!
I got the blank plate off.... put it all back together and now its abit smokey, more like steamy smoke really if that makes sense... its kinda white in colour!
Would this just be all the gunk clearing out? unfortunately i cant take it out for a good clearing out as it has no mot?
i cudnt get the egr valve off enough to be able to clean it without making more work for myself anyway!! , so i ended up cutting the plate out.
Any thoughts appreciated!
thanks
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 7:23 pm
by johnboy
Oh also engine management light and anti pollution warning still on! grrr
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 8:09 pm
by eoin27
Anti-pollution is not good. It could be the CAT that failed the MOT.
I'd give the MAF a good cleaning if it has one. I know nothing about HPi's (except I know I want one)
I'd spend a few quid on an EGR solenoid from the stealer.
I'd give it a good thrashing and then clear the codes
I'd then probably pass the MOT :cheesy:
Re: EGR Suprise!
Posted: Mon Apr 26, 2010 8:13 pm
by johnboy
Yeah its got a MAF. On inspection of the top breather hoses they are badly gunked up with oily gunge, so much so that ill prob get a new one, its not helping matters i dont think!
im just hoping the smoke clears abit maybe a few more warm up's with abit of revving mite clear it out?
when i get the new pipe ill prob take apart the breather hoses and clean them out! :cry:
Re: EGR Suprise!
Posted: Tue Apr 27, 2010 9:04 am
I would say your newly-opened air path is allowing oil/gunge to be burnt through the egr tubing (when the EGR recirculates). It's basically taking hot exhaust gas and passing it back into the inlet manifold; if it hasn't been doing this for a while then oil will be getting burnt off for a while.
The function of the EGR is to lower combustion temps and lower NOx emissions (maybe why it failed the MOT with it blanked off). It's not generally beneficial to blank off Petrol EGR's unlike some Diesels.
I think you'll need a new EGR and new replacement tubing back to the manifold.
Re: EGR Suprise!
Posted: Tue Apr 27, 2010 7:48 pm
by johnboy
Well ive taken apart the top breather hose, the one that runs from the MAF over to the manifold (The one thats all blocked and oily) i rang peugeot and ordered the replacement pipework which is £22... not too bad, tis easier to replace then clean coz its broken up and oily! so will help hopefully.
The metal flexi pipe which comes off the EGR was oily inside yesterday so will tackle that when i replace the EGR. By the way.. how the hell do u get the thing out? i could only move it back about 2 inches off the block, what do i need to remove?
Where is this oil coming from? i think i need to replace my rocker gasket anyway as it is leaking badly!!! would this be the cause?
Leaving the other bits for now as i wanna make sure the engines running right first.
Re: EGR Suprise!
Posted: Tue Apr 27, 2010 11:15 pm
by johnboy
The pipe marked yellow is the one that im replacing thats gunked up!
Also whats the bit in the red box?? looks like sum kind of dump valve? lol
Cudnt c how to insert an image so heres the link:
http://img33.imageshack.us/i/dsc03499l.jpg/
Re: EGR Suprise!
Posted: Wed Apr 28, 2010 10:01 pm
by johnboy
pleaseeeee help
Re: EGR Suprise!
Posted: Thu Apr 29, 2010 7:10 am
I think the problem here is we honestly don't know how to help :oops:
The HPi is very rare and having detailed knowledge of replacing its EGR even rarer.
Re: EGR Suprise!
Posted: Thu Apr 29, 2010 8:00 am
by DaiRees
Yeah sorry John, like Welly said, you're the trailblazer on this one (but I'm very interested to know whatever you find out) :oops:
I think the bit in the red box is the throttle body motor, if you take the big hose off that's coming from the air filter you can see the butterfly valve in there, I reckon the bit you've boxed is the motor that operates that butterfly.
