car acting as if its misfiring
Posted: Thu May 06, 2010 2:47 pm
by barryemm
hi guys recently my car developed this chugging when started from cold its fine when it reaches working temperature sometimes it sounds as if its about to cut out any ideas what this could be
Re: car acting as if its misfiring
Posted: Thu May 06, 2010 2:49 pm
by mjb
What engine?
Posted: Thu May 06, 2010 2:50 pm
by barryemm
sorry forgot about that lol 2.0l hdi 110
Posted: Sat May 08, 2010 6:03 am
by FlySpeck
sounds like poor glow plug performance, a cold diesel engine will chug (if it starts at all) when the glow plugs arent hot enough, hence it runs fine when warmed up.
Also sound very clattery and go "glug glug glug" kinda noise for the first half minute or so dont you find?
Posted: Sun May 09, 2010 6:50 pm
by barryemm
yes mate thats exactly what mine does was having a look at the engine the other day and noticed my fuel filter housing was broke one off the pipe connect lugs was broken also noticed it was also sealed with some sort of glue a got this car of my cousin she took it too a garage to get it service n looks like it hasnt been serviced at all she said it got serviced 3 month ago and the car has sat for 2 month the air filter is black the oil filter is rusty poor glow plugs and its clear the fuel filter hasnt been changed so am going to do all this tomorrow
Posted: Sun May 09, 2010 6:53 pm
by FlySpeck
lol sounds like she was had by them eh.
use copious amounts of wd40 on the glowplugs (engine warm but not hot) so you dont snap one in the head....they are little b*st*rds to remove sometimes....and a broken one will not be a good thing...in fact its a very bad thing :(
Posted: Sun May 09, 2010 10:57 pm
by barryemm
yeah she was had by then alrite they charged her £300 for a new fuel pump and labour charges and they never replace the fuel pump but instead disconnected a pipe and when she was driving all the diesel came out
thanks for the tip mate
Posted: Sat May 15, 2010 1:23 am
by FlySpeck
I found out today that the glowplugs on the HDi are only used under ecu control when the engine is in extreme cold, as direct injection diesels dont depend on the use of glowplugs to start, so they help, but are not necessary.
Next I would check the engine coolant temp sensor, as the ecu may not realise the engine is cold and hence not add the extra enrichment fuel for smooth cold running...
