406 2litre idle prob
Posted: Fri May 14, 2010 8:13 pm
ok my pug idles around 500 to 800 by the needle rising n dropping slowly while idle ..drops to almost stalling at times during stopping ..then ever so slowly creeps bk .. its worse when say the radio and blowers running basically more electrical load the rev needle drops like a stone after say reving engine to 2000 rpm to almost stalling before kicking bk in to life even if idling
swopped parts with working ones
MAP
TPS
ICV
coolent sensor
no air leaks
been told its running rich tho and to replace the lambda sensor?? which i looked at today was black n that so cleaned it n put it bk but still this idle prob...could it be this sensor ?
MAP
TPS
ICV
coolent sensor
no air leaks
