Problem with uneven engine whilst driving at around 2000 rpm
Posted: Sat May 15, 2010 12:25 pm
Hi all, I hope you can help me.
I have a 2001 (Y plate) 2.0 406 GLX (Petrol).
Recently, when it is warm the engine misbehaves. It's a tricky issue to explain but let me try.
It accellerates really smoothly and well, it engine breaks smoothly too.
Buut, you know the spot where you are neight accelerating or decellerating? Just when you are hovering your foot on the pedal? The engine seems to be "jerky" making the ride feel stuttery. If i accellerate slightly it gets better. Accellerate a bit more, it stops happening. It does not always do this but it is 90% of the time - but only noticable when the engine has warmed up at about 2000 rpm
Idleing is pretty smooth, although it went through a period a couple of months ago at stalling when idling.
I've changed the spark plugs in a hope that would solve the problem. It hasn't.
I'm not an expert, but I should be able to have a go at fixing it myself as long as it'd reasonably simple, but I'd appreciate it if anyone has any ideas?
Thanks.
Thanks.
