Once upon a time... well, actually, every morning I am greeting by a damp patch by my car under the radiator area... Lovely..
Looking under the car I see where the coolant is leaking from.. ish...
This, as you can see, dampens up the whole of the engine undercover thing and the leak can sometimes be seen from anywhere along the edge of the cover..
I had my car serviced at a local Pug specialist dealer who said he couldn't find the leak in the radiator. So... where can the leak be coming from?! I was thinking one of the hoses, but looking inside the engine, I can see a damp patch right under the radiator. But how could the dealer not see it?
I keep topping up the coolant once a week now as it drops below the min level in the reservoir. Are there any vulnerable areas of the coolant path that I could easily check? On a sunny day I will probably get under the car and get undercover off to see if I can spot anything...
Any advice appreciated
