fuel supply/starvation
Posted: Fri Jun 04, 2010 6:10 pm
by Archangel
'having trouble with fuel supply.
bulb is not full and hard when squeezed and having starvation probs.
I need help ! was okay just started last few days , new filter fitted last week
"R" reg 406 diesel 1998 ? GLX 233k miles
Re: fuel supply/starvation
Posted: Fri Jun 04, 2010 6:20 pm
by DiscoPol
have you checked there is not a seal issue round the filter housing?
checked for cracks on housing and supply lines?
it seems too coincidental that a new filter went on last week and now you have air getting into the system allowing the diesel to drain back giving the the less than tumescent bulb, did you do the filter yourself or was it a garage?
Posted: Fri Jun 04, 2010 8:16 pm
by Archangel
no air appears in the system , bulb is almost flat as though there is a suction? ,filter housing is fine
is there a pump in the tank? does that have a filter?
i did the filter , exactly same as on the 306
Posted: Sat Jun 05, 2010 4:11 pm
by swiss
There is no pump in the tank but there is a gauze filter on the pick up. Do a search, there was a topic recently whereby several people found theirs to be clogged with gunk. I checked mine and found it to be spotless, but it seems worth a look.
Short version, you remove the back seats and unscrew the plastic tank cover. It's more tricky than that though, so dig out the topic for more details
Posted: Sat Jun 05, 2010 9:30 pm
by Archangel
thanks for a sensible reply, will look at tank pickup for possible gunk
Posted: Sat Jun 05, 2010 9:48 pm
by poddack
search for before and after
Posted: Sat Jun 05, 2010 9:52 pm
by poddack
Posted: Sun Jun 06, 2010 7:32 pm
by Archangel
swiss wrote:There is no pump in the tank but there is a gauze filter on the pick up. Do a search, there was a topic recently whereby several people found theirs to be clogged with gunk. I checked mine and found it to be spotless, but it seems worth a look.
Thanks for that useful info , also guy i bought the car off said same thing , cleaned gauze mesh and now runs right
Posted: Sun Jun 06, 2010 7:33 pm
by Archangel
no topic now available , thx for trying Poddack
