1.8 d8 running temp
Posted: Thu Jun 17, 2010 3:41 pm
by gordonw
Can anyone tell me what the temp gauge should read on a 1998 1.8 d8 406 is ?.Since i got the car it has been showing 70 on the gauge in normal running,it now shows 90 in normal running and the electric fan kicks in at 100 and it goes down to 95 when idling then returns to 90 when driving again can anyone tell me what the normal position is as a reference point.Thanks
Re: 1.8 d8 running temp
Posted: Thu Jun 17, 2010 4:09 pm
by jord294
sounds like it's running fine.
anywhere between 70` and 90` is the norm afaik
Posted: Thu Jun 17, 2010 4:35 pm
by gordonw
Thanks for that didnt think i had a problem just wanting to know what was a >normal < reading.Many thanks
Posted: Thu Jun 17, 2010 8:48 pm
by highlander
My '99 1.8 D9 runs at about 80 to 90 C, and
never goes higher than 90, even on really hot days (yes, we have them here in Aberdeen sometimes), and even if I'm a bit heavy on the loud pedal (well, heavier than usual anyway
Not sure if the cooling system is better on the D9 lump than on the D8.
Just my personal experience.
Posted: Thu Jun 17, 2010 9:03 pm
by swiss
My traktor runs at 80 when I'm under way and there's air over the rad. At a standstill on a hot summer day it gets up to 95 but no higher. AFAIK my fans have never kicked in, even after I proved they work ^_^
Posted: Thu Jun 17, 2010 9:40 pm
by kevtherev
funny this post shud appear actually as i wasnt convinced mine was running correctly . mine would run at 70 then 5 min of stop start traffic and its 90 and beyond had it up to 100 which to my thinking aint right so removed stat it didnt get warm when running but the same prob in stop start traffic up it went again . got a new stat so monday morning was spent flushing the system fit stat bled it all new coolant and now it runs at 80. creeps up to 90 in traffic but takes longer and kinda settles at 90 now
i am fairly sure i had an airlock before coz i undid the bleed screw at the bulk head months ago and water trickled out which i thought was ok but having done it again on monday i gave the pipe running from the stat housing to the rad a squeeze ( with the guage at 90/stat open )and had coolant shooting 2 inches out like it had shifted air out
hope this helps
kev
Posted: Thu Jun 17, 2010 10:17 pm
by tenwierdufos
My d8 2.1 12v diesel would run at 70, all the time, no matter how hot or cold it was outside.
Posted: Thu Jun 17, 2010 11:08 pm
by teamster1975
gordonw wrote:Can anyone tell me what the temp gauge should read on a 1998 1.8 d8 406 is ?.Since i got the car it has been showing 70 on the gauge in normal running,it now shows 90 in normal running and the electric fan kicks in at 100 and it goes down to 95 when idling then returns to 90 when driving again can anyone tell me what the normal position is as a reference point.Thanks
Around 80-85c. Don't think you've got a problem but give the coolant a bleed for good measure; it's a 5 minute job
Posted: Sat Jun 19, 2010 12:07 pm
by gordonw
Thanks to all, gauge now showing over 100 in traffic so will investigate further.Is the bleed screw near the bulkhead .
Posted: Sat Jun 19, 2010 1:44 pm
by teamster1975
gordonw wrote:Is the bleed screw near the bulkhead .
There are two; one on the heater matrix (bulk head) and one on the thermostat housing.
Park with the front o/s wheel on a kerb to get the filler above the height of the bleed screws; start with the 'stat screw and then the matrix.
Posted: Mon Jun 21, 2010 2:13 pm
by kevtherev
teamster1975 wrote:gordonw wrote:Is the bleed screw near the bulkhead .
mine hasn't got the bleed on the stat housing only at the bulk head. i think the 2 litre tubby has a different set up.
Posted: Tue Jun 29, 2010 2:32 pm
by gordonw
thanks to all,there was air trapped in the system gauge now sitting at 80 constantly thanks again
