A common mod on the 306 forum is to put the 306 HDi gearbox on a 306 TD with the TD's clutch fork, flywheel and clutch.
We think my Uncles DMF has died on his 406 so wondering would we be better getting the solid item from the 406 TD, along with clutch fork and clutch and putting it in his HDi.
Anyone spare any throughts on this please?
HDi 90 vs TD Clutches?
- Bailes1992
Re: HDi 90 vs TD Clutches?
Dont think the HDI 90 has got a DMF ...
- Bailes1992
Right theres a constant scream comming from the gearbox, when I got in the car the clutch was on the floor, I picked it up and it seemed to operate fine again. Scream still there though. Moved it to the other side of the drive and theres a smell of burning and the clutch seems to slip.
FOOKED !!!
sounds like thrust bearing gone for defo and probably
clutch plate unless bearing has disintigrated and jammed something .
forgive my lack of knowledge what the f**k is a DMF ??puggy wrote:Dont think the HDI 90 has got a DMF ...
Replacement !
- highlander
- PowerFlow Shill
Dual-Mass Flywheel
a type of flywheel where the rotating mass is split into two pieces. These are joined by a damping mechanism to disperse torsional vibration from the crank shaft.
Thanks Highlander for the straight replyhighlander wrote:Dual-Mass Flywheel
is it only good for a HDi then or would it be good for a TD ?
Replacement !
