Air filter housing screws
Posted: Thu Jul 01, 2010 11:03 am
by rwb
Hi,
I went to change my air filter last night, but the screws on the housing have rusted. One would move, I stripped the head on one, and I left the other two well alone.
So:
  • Any ideas how to get the screws out.
  • Can I get replacement screws from somewhere?
Ta.
Re: Air filter housing screws
Posted: Thu Jul 01, 2010 11:55 am
by gumby6371
Getting the screws out is just a question of finding something that will grip and turn them, mole grips or good pliers should do it. Replace them with virtually anything that will fit. When I bought my d8 one of the screws had been replaced by a nut and bolt. Basically anything that clamps the lid on will do and shouldn't affect the airflow. All depends on how fussy you are on keeping the engine bay looking nice. With mine i have too many dents and scratches (all from previous owners I might add) to worry if the original spec screws are holding the lid on the filter housing :lol:
Posted: Thu Jul 01, 2010 1:01 pm
by omega
or you could just replace the whole unit with a new one.......and yes i do have one if you need it :cheesy:
Posted: Thu Jul 01, 2010 9:00 pm
by rwb
ta. I shall mount a more aggressive offensive on it at the weekend.
Posted: Thu Jul 22, 2010 9:03 pm
by rwb
Can't shift em :(
Probably going to have to pay the mechanic :evil:
Posted: Thu Jul 22, 2010 10:36 pm
by jasper5
I use a pair of small pointed nose mole grips, get the screws to move a little then spray WD40 around the screws, let it soak in for a few minutes then they usually undo fairly easy.
Posted: Thu Jul 22, 2010 10:51 pm
by teamster1975
Cut a slot in the screw head, soak the screws in WD40 and try a large flat headed screwdriver. Failing that cut the screw heads off!
Posted: Mon Jul 26, 2010 1:12 pm
by mjb
For the cost of a mechanic, you'll probably be best off just buying a new air filter box off ebay. The screws aren't removable so they're not listed as parts you can order
Posted: Tue Aug 10, 2010 10:01 am
by rwb
Well my dad managed to get the buggers out, and back in again!
First, he spent quite some time cleaning the screw heads, using a small flat blade screwdriver to broddle out the x-shape on the screw head. I had soaked with WD40 at my first attempt, so this had already softened the rust.
The main part of the genius, though, was a philips head screwdriver but with the point ground off by about 1/16". The flat end lets it sit right down inside what remains of the screw head. It still required a lot of pressure to keep the driver in the screw head to turn the screw.
The screws went back in with a bit of copper slip on them, so maybe if anyone tries to get in there again -- after another 5 years -- then the poor fools may stand a slightly better chance of getting in first time.
Posted: Tue Aug 10, 2010 12:18 pm
by Springnuts
Well done, and thanks for the tip on copperslip. I have just ordered a second hand housing since the garage thoroughly mangled the lid when they changed the clutch - broke one of the tabs and messed up the screws on another - resulting in the lid not fitting properly. Regards, Springnuts
