hdi 110 not starting
modified406
Post by modified406 »
hi guys my hdi 110 isnt starting theres diesel going to the injector all fuses r ok batterys brand new its as if my injectors arent openin to allow the fuel through
modified406
Re: hdi 110 not starting
am getting fuel through the injectors could it be possible that my key has lost its programme and therefore needs to be reprogrammed
mickeydread1122
Post by mickeydread1122 »
could be anything mate can't you have a colleague who can tow you away for a quarter of a mile and call either RAC or AA to properly diagnose your car and have fault code read.it can be the fuel cut-off switch or the low fuel pressure which might be causing the non start issues.when you attempt to start the car is there an orange key symbol on the dash and the message of engine immobiliser fault on the multi function display screen ???????
there are several faults that can cause these cars not to start especially HDIs being
1) immobiliser fault
2) low fuel pressure system
3)in-tank fuel pump and lastly low- compression as well.
if i was you i will have the car towed a quarter mile then call AA or RAC then you can go from there :wink:
modified406
theres no faults about immobiliser coming up on the wee screen and there is no orange key symbol i was really hopin that it was jst air in the system
mickeydread1122
since you have ruled out the immobiliser fault i think you need to bleed the fuel lines then, maybe there is air in the fuel system.did you happen to recently run on very low fuel recently as HDI engines are very complex 1s.is yours a bosch or siemens system ? check the fuel filter if there are any particles in there that might have contaminated the fuel lines plus also i would check the fuel injectors if there is any leakage that might be causing some low fuel pressure.
modified406
i bled all fuel lines its a bosch system also its been a new fuel filter thats been put in it could it be possible that the injector cleaner i used has knackered my injectors its for a diesel system but i was told to full my housing up with injector cleaner
diesel406
Re: hdi 110 not starting - SOLUTION!!??
Post by diesel406 »
Ok - mine did this and it was the immobiliser not recognising the key - yes - a stupid Pug problem - what was required was a wipe clean of the central brain and re-load.
You need a car electrics specialist to sort this with an OBD II programmer - not the cheap ones on eBAY .. a full reader and programmer. You will not necessarily get anything message on the car screen. I read you eliminated this but I would be very careful about dismissing this ...
Easy to fix if you have one of these and shouldn't cost more than £30 for a diagnosis and perhaps £20 more to fix.
Engineer by day - Car mechanic by night - there is a difference!
Now gone to the German Dark Side!!!
At work: http://www.fatigue-expert.com and http://www.xanthusenergy.com
modified406
finally got it started just need to figure out y its not going over 2800rpm
diesel406
Post by diesel406 »
modified406
thanks that sounds alot like my problem i have spare solenoids as i got them from another car so will try them also after i have switched the ignition off the engine still runs for 5 seconds what could be causing this
pugface406lx
Post by pugface406lx »
hi...do u know how to reprogram key?....i had same problem and someone showed me.....put key in ignition, turn to on...lights on dash.....and press locking on key to activate central locking
it seemed to work for me
modified406
thats only to reprogramme the key for central locking
