engine sump plug tool (torx size) for 2.0HDI
Posted: Sat Jul 24, 2010 1:52 pm
by pugface406lx
Hello guys,
2000 'W' Reg 2.0HDI
Can anyone tell me the torx screw size for my engine sump plug nut please....trying to remove the oil but can find the right tool to release it, a spanner cant really get enough on purchase on the nut.
Re: engine sump plug tool (torx size) for 2.0HDI
Posted: Sat Jul 24, 2010 1:54 pm
by Doggy
I think these vary a bit from car to car, but mine's an 8mm allen key.
Posted: Sat Jul 24, 2010 2:05 pm
by pugface406lx
Hi...thanks dogslife but mines definitely a Torx screw....if i use anythin else i fear i might round the inside of the shape.
Someone just said he thinks its a T30 ?...Anyone able to confirm?
Posted: Sat Jul 24, 2010 2:41 pm
by jasper5
What size spanner you using? You need a 21mm or 13/16th old type.....same size as an old type spark plug socket, you not got a socket?
I've never seen one with a torx fitting, they have been 8mm allen key or the usual French square size, 8 or 9mm square.
Posted: Sat Jul 24, 2010 4:06 pm
by DiscoPol
I know it doesnt help you mate, but mine is an 8mm hex driver (allen key) for sure and im in a 2000 W reg 90 Hdi
Polski
Posted: Sat Jul 24, 2010 9:04 pm
by pugface406lx
Hi,
Got it off eventually with a combo of using a spanner and T50 torx socket /screw. Was overtightened by last bloke who changed the oil i think, Anyhow will have to get a new sump plug next time round.
Looks like its been changed as you say should be square drive in the end not Torx.
Puggy
