3.0 v6 purge valve
3.0 v6 purge valve
hi new to the forum so hope this is the correct place to post as not sure wether this is to do with engine or electrical, i think ive narrowed my problems with my car down to the purge valve but i cant see it causing so much problems, its a 3.0 v6 on a 98, basically when driving along i get a jerking when trying to cruise, sometimes not so bad and others its really bad, although letting off the throttle or slightly accelerating will stop it for a while, ive used a code reader and the purge valve solenoid circuit code always comes up, im guessing as its unplugged, i have found a brown plug near the ecu unplugged but cannot find anything to plug it into, so does anyone know what that plug is or have a photo of a purge valve so i can find it? or if you have any idea what the real problem is that would be better, thanks chris
Re: 3.0 v6 purge valve
viewtopic.php?f=10&t=8145
It's the brown thing stuck on the ECU box
