Can any members with service box access please look up the part number for the alternator belt tensioner please.
I've developed a nasty rattle when accelerating while the power steering pump is active. A mechanic mate of mine told me where the tensioner mounts on the engine block the hole has elongated and with the extra tension on the new belt it's causing the rattle.
Not sure if I need to buy the whole unit as it all seems ok except for the actual mounting point.
Car details are 97 1.9td with aircon
If possible a screen shot of the components would be great.
Thanks in advance.
anyone with service box access out there
Re: anyone with service box access out there
4 DOOR SALOON AND DIESEL XU AND AIR CONDITIONING (I presume this is the 1.9TD...)
575130 TENSION ROLLER (tensioner pulley) £97.06
575181 TENSIONNER (the spring) £82.30
575129 TENSION ROLLER (idler) £93.66
- Captain Jack
Quite expensive for what are essentially springs and metal wheels...mjb wrote:4 DOOR SALOON AND DIESEL XU AND AIR CONDITIONING (I presume this is the 1.9TD...)
The tensioner (on the ES9J4 at least) is a substantial lump of metal and prone to corroding and seizing (long shaft so you'll never free itCaptain Jack wrote:Quite expensive for what are essentially springs and metal wheels...
Ok so speaking s-l-o-w-l-y and in small words as I'm having a bad day, which bit mounts on the engine as I think thats the only bit I need
if its the same as a 2.1 i have one
Had a quick look on the electronic bay and managed to pick up the spring and bottom roller for £60 plus £3.50 p&p so quite pleased, thanks for the advice.
