hello all, had a new clutch fitted 6 months ago 1.9td bout a month back car got a bad judder in reverse only but now its also doing it in 1st gear , its very bad when the engine is very hot and car has been in use for over 2 hours,
can a clutch really fail after 6 months ? what would be the reason for this ? wrongly fitted ?
the person that fitted it says the clutch MAY be covered under guarantee BUT labour isnt and i will have to pay for a new clutch fitted again
Sounds as though the release bearing may be sticking, did they replace it with the clutch?
ye i thought engine mount because when i start the car up everytime there is a loud KNOCK noise, only when the engine fires is the KNOCK felt and heard
its as tho the engine jumps and knocks as it lands ????
Gary406 wrote:the person that fitted it says the clutch MAY be covered under guarantee BUT labour isnt and i will have to pay for a new clutch fitted again
WRONG! If they screwed up (and a dodgy clutch won't cause judder, just poor fitting) then they're legally obliged to fix it
However it does sound like an engine mount...
Yes, your cable could cause the judder, but make sure your engine mountings are in good condition first.
I have had judder with driving school cars where the dust from the clutch material has clogged the bearing slide and when warmed up causes the bearing to stick on its slide....lack of correct lube on the slide can also cause judder (sticking bearing).
Check the terms of your warranty, did it include parts and labour? Most clutch warranties might not cover the labour, if the clutch is faulty, the garage could quite rightly argue that there was nothing wrong with their work so they are entitled to get paid for replacing the faulty clutch....unless as I mentioned, you have a parts AND labour warranty.
Gary406 wrote:when i press the clutch peddle you can feel a sticky squeeky noise as well as feeling it in your foot,
The exact symptoms for a rusted clutch cable. Lubricating won't do anything more than mildly ease the problem for a day or two - you need a new cable...
okcheers for that mjb will get a new cable fitted at the weekend, im also getting a slight squeek from the bar that goes into the gearbox at the top that the cable pulls forward, im thinking get the nylon bushes changed with the cable
