406 1.9td how long.....
.... are these engines and gearboxes going to last? it's a 99 t-reg done 85k 2 owners serviced every 8k?
Its had a fair amount spent on her, brand new rad, new drop links, local garage thinks she in good condition.
Just looking for advice as im thinking of selling and buying a estate model, or do i stay put.
1999 1.9 td lx saloon.
Re: 406 1.9td how long.....
serviced every 8k..........forever!
Hmmmm, straight 6 goodness!
Typical lifespan seems to be generally 200k+
As you've got a late, low-mileage example of one of the last engines that'll run on veg oil there should be some interest if you want to sell it.
I'd go for the estate, but then i'm biased.....
your car has had all the general stuff done to it, i would stick with that, i have same engine 1998 123k miles , apart from the odd drop link failure and clutch & accelartor cable issues its never let me down, brilliant car would not change it for anything at the moment,
love it that much im paying £250 this week for a new cambelt fitted so i plan on keeping it for a long time
mine 235+k , running on biodiesel (home processed variant not Morrissons sh*t ) replaced starter motor last week, and is GLX estate version 1998 1.9TDadamr8965 wrote:.... are these engines and gearboxes going to last? it's a 99 t-reg done 85k 2 owners serviced every 8k?
Replacement !
Thanxs guys, may stay put then. But its difficult with two children and two buggies in a saloon model,
If i was to sell it would be looking for around £750 mark. Anyone looking to sell a diesel estate model?
they wont be children for long mate , i know what u mean tho i have 3 kids 6 and 5 year old grown up now out of buggies, only the 1 buggie left for the 2 year old, grin and bare it out before you know it they will not be in buggies anymore
but if u was to sell it i think you would have no problems at £750, you may push a bit more on fleabay, i would certainly try £895 first
not many with that milage left
Yeah i know gary, also have to black labs aswell. Only bought the car as a stop gap. But have been most impressed with it so far.
good luck which ever way you go mate
Cheers gary, put her up for sale see if theres any interest with her.
Don't mean to hijack but would like to test the water here, I have a 1996 406 Exec, 173,000 - paid £400 and love it, my problems are thus -
1. fitted new brakes (drum rear - disc front) both discs/pads and drums/shoes - now abs light on - on from ignition
2. Rattling from altenator - saw that belt was 'flapping' about at the bottom - new rollers top and bottom - stopped the flapping but still noisy - crank pulley not split or owt, got big screwdriver in near spring and pressed, seemed to take noise off - could it be broken (spring I mean) can't see it flapping about
3. Seems to get hot easilly, give it some boot and it'll bob up to 103 C - should it go up so easy under load? Drops easy as well, back to 90 C - chemically flushed radiator
I was toying with getting shot but might get one just as bad - still tonking along at 100 on motorway - went to Scotland and got 620 miles for a tank (well chuffed) starts 1st time every time, bit of grey smoke on start but no clouds - my question is, would you fix it or get shot and any ideas what could be the issue with these faults listed above?
Cheers
Gaz
And your opinions will influence what happens - ohhhh the power
Cheers
Gaz
i would fix it, if it was mine,
abs light not to sure about but it cant be major if it only came on after fitting new brakes,,,,
did you bleed the cooling system correctly after flushing ? with the 2 nipples ,
few minor problems they seem defo wouldnt sell it ,
- Site Admin & Mad Biker!
ABS light may be a wire come off one of the pads, I had this on mine. Also check the wiring isn't damaged going to the socket for the pad leads.
As Gary says I would double check for air in the cooling system.
See that's what I'm thinking - just got the following from a bod on flea bay for £75
F/driver Headlight as that thumb adjuster jobbo had snapped
2 month old tensioner spring
passenger air bag cover
spotlight holders (x2)
both heated seat switches
The gubbings and reciever for the key fob
2x front abs sensors
