What bits can I use to get more performance?
Posted: Tue Sep 07, 2010 10:54 pm
by no2lurch
I have a w reg Sri estate and I want to get a bit more from it performance wise.
It's currently in standard form apart from the removal of the resonator on the air box.
What can I use off other pug models to gain some 'go'? Can I change injectors, throttle body, inlet etc?
Re: What bits can I use to get more performance?
Posted: Fri Oct 15, 2010 8:24 pm
by TRAVIS BICKLE
depends how deep your pockets are :cheesy:
Posted: Sun Oct 17, 2010 11:55 am
by linukas
bigger turbo,
injectors,
change intercooler,
fuel pump and so on
Posted: Sun Oct 17, 2010 12:40 pm
by TRAVIS BICKLE
linukas wrote:bigger turbo,
injectors,
change intercooler,
fuel pump and so on
I think he has the 2.2 engine as its a W reg and a d9. Id be interested to see what can be done to these, turbocharging one of these would be a good way to big power. DP Engineering list a turbo kit for about 2500 euros, but on top of that you would need to budget for pistons, rods, gaskets, new management, exhaust system, cooling etc etc, big money really :shock:
Going NA you could get the head ported, some decent cams, a good manifold and system, go throttle bodies and stand alone engine management.......Im getting carried away again :oops:
really to see any worthwhile gains its going to cost loads :(
Posted: Sun Oct 17, 2010 4:16 pm
by HimBigChief
Cheapest option to any meaningful power would be to drop in a V6 really.
Posted: Sun Oct 17, 2010 6:47 pm
by TRAVIS BICKLE
HimBigChief wrote:Cheapest option to any meaningful power would be to drop in a V6 really.
True :)
Posted: Mon Oct 18, 2010 8:30 am
by no2lurch
injectors,
change intercooler,
fuel pump and so on
bigger turbo - doesnt have a turbo as its a petrol
injectors - to which ones, and would it need any other mods to accept them?
change intercooler - doesnt have a turbo as its a petrol
fuel pump and so on - to which one, and would it need any other mods to accept them?
Posted: Mon Oct 18, 2010 12:12 pm
by linukas
injectors,
change intercooler,
fuel pump and so on
thought you got older sri as i got. I think i agree with others that cheeper to get V6.
but you can still play with cams, throotle bodies etc. But its just not worth to spend a lot of money and get 60Hp
