110 hdi low fuel pressure
Posted: Tue Jul 25, 2006 9:18 pm
by fooked pug
low fuel pressure problem.2001 110 hdi. ive already changed the pump in the tank in november but now i have very low pressure at fuel rail.ecu checked out ok.any one else had this problem?wiring problem or high pressure fuel pump????
Posted: Tue Jul 25, 2006 9:24 pm
by turbolag
fuel pressure sensor? Main pump failure? A leak? A blockage?
Posted: Mon Aug 07, 2006 10:46 pm
by fooked pug
had it checked today ............ high pressure pump buggered :cry: loads off money
Posted: Tue Aug 08, 2006 9:52 am
What a Bummer :cry:
What did they do to determine the HP pump was worn?
Posted: Tue Aug 08, 2006 12:36 pm
by Foghorn Leghorn
I had heard that if your low pressure fuel pump goes you should change all the fuel lines, fuel filter and housing and fuel tank too, otherwise the bits from the tank pump kill the high pressure pump :cry:
Fog
Posted: Tue Aug 08, 2006 12:43 pm
by robconnors1977
It allways seems to be the 110 bhp that suffers from fuel pump faliure, never the 90?
Posted: Tue Aug 08, 2006 2:59 pm
Also a nice tank full of Unleaded does nothing to help the pump(s).
On some cars you might just get away with it if your quick, but the damage is done, the pump will still fail later on.
Tis a real shame the HP pump is so expensive, it won't be long before a pump failure will effectively write the car off :|
Posted: Wed Aug 09, 2006 8:00 am
by fooked pug
the pump has to be removed and checked on a fancy machine,should be a couple of hundred psi,someone told me about cleaning the pipes but i would think thats the case if the pump starts to break up i think i'll do mine anyway just to be sure
