random cutting out result.
Posted: Wed Sep 15, 2010 7:04 pm
by billy406hdi90
after all the guessing and replaceing parts the garage called 2day and said its the wireing beetween the lift pump and the front so a temp fix is a constant live feed to the pump has any1 heard of this happening b4?
Re: random cutting out result.
Posted: Wed Sep 15, 2010 7:21 pm
No, but there's always the possibility of wiring damage/corrosion or bad connectors. Has it cured the problem?
Posted: Wed Sep 15, 2010 7:32 pm
by Doggy
I had this on a HDi 90 Xsara - on that the wire went directly from fuse to lift pump. so you could get it going by connecting a perm. live to that end of the fuse holder via a spade connector.
Eventually proved an open cct in the loom, never found it, just connected the bits that were supposed to be connected together with another bit of wire.
Posted: Wed Sep 15, 2010 9:24 pm
by billy406hdi90
it will b getting done on friday but i think i will b selling the car as i feel the car has brought nothing but bother so will see how things go.
