Leaking Hdi High Pressure pump
Posted: Wed Sep 22, 2010 8:29 pm
by hammerman
My 2003 Hdi 110 has started leaking diesel from the high pressure pump :roll: As you look at it from the front of the car,there is some kind of unit fitted to the end of the pump(opposite the cambelt side)with a plug.It is leaking from the underside of this unit,which seems to be fitted with 2 bolts.It only leaks when driving,quite badly.
I would assume that if i unbolted it i would find some kind of O ring or seal that would need replacing.Has any one removed it themselves,& is there anything inside that might "fall out" if you see what i mean.
The unit is at the end of my finger in the pics.Thanks in advance :)
Re: Leaking Hdi High Pressure pump
Posted: Wed Sep 22, 2010 8:51 pm
by Doggy
Have no idea whether it's easily fixed or not - maybe a diesel specialist?
Spotted a couple of potential replacements on fleabay: 180562220344 & 180563517327
2nd one's brand new for £150 which could be a bargain.
ServicePox is down so I can't check part no.s :roll:
Posted: Wed Sep 22, 2010 10:17 pm
That's an electro valve apparently. There's a gasket of some sort under it, plus a support ring and a couple of o-rings it looks like. FFS Pug want 346 quid for the valve :shock: :shock: :evil: and a couple of quid each for the gold-plated o-rings :roll:
Come and get me copper :frown:
Posted: Thu Sep 23, 2010 4:41 pm
by hammerman
Thats just what i was after thanks Steve :D
I`ve taken the valve off but cant see anything wrong.Just going to cut a new gasket with some gasket paper to see if that fixes it.My local dealer has ordered a new gasket(no 5 in the pic),will cost a £2 :D .And the whole valve costs £295 + vat :shock: :shock:
Posted: Mon Nov 15, 2010 7:46 pm
by kangtdi
hi all,
I have a peugeot expert 2.0 hdi 16v 2004 model. Recently it has had a smell of diesel whilst driving and has struggled to start in the morning. Well in last couple of weeks when its been really cold it wont start. Until the battery just dies. But if i jump it with leads on another battery and keep cranking it , then eventually it fires and is perfect from that point onwards, no problems with it after that what so ever.
When i started investigating i noticed a small patch of diesel on the floor and whilst looking under the bonnet i noticed the high pressure fuel pump looked kind of wet underneath it, as i touch the bottom end of it, it is very wet with diesel.
Do you think this is what is causing the problem?
Kind Regards
Posted: Mon Nov 15, 2010 9:59 pm
by ianjoh
Any leak in the high pressure side of the pump is bad news for instant starting if at all.
The output pressure is monitored on the common rail and will not allow the injectors to fire if it is too low.
The Electro valve is the gadget that regulates the fuel pressure on the pump, it is driven by the ECU that supplies it with variable width 12v pulses.
Posted: Mon Nov 28, 2011 10:16 pm
by hammerman
Well,i got all the gaskets etc from the dealer.Could`nt get it to seal.Took it to a diesel specalist,£90 to fix,been dry as a bone ever since(3 mths)
