car just cut out and wont start
sween23
Post by sween23 »
hi all, just wondering if someone could help. I have a 96 sri turbo and for some reason this morning on way to work it just completely cut out and now it won't start at all.everytime i try and start it it just clicks and my warning lights are on and engine management light stays on.Is this a saftey thing on the car or havei got a major problem,cheers
omega
Re: car just cut out and wont start
Post by omega »
check battery connections and cambelt
Does sound as though the battery is flat, check the auxilliary belt is ok for starters, also check your voltage across the battery. Can you get a jump start off anyone?
I've not known a cambelt go on one of these but I guess there is a first time!
Welcome in btw! :)
sween23
Post by sween23 »
cheers for reply,everything with battery is fine and if im looking at the right belt then thats ok aswell.Its just baffled me i was overtaking a wagon and everything just completley cut off and it just ticks now when trying to start it
omega
Post by omega »
have you checked to see if there is any fuel getting to the engine?
sween23
Post by sween23 »
yep there is
omega
Post by omega »
if it just clicks it could be the starter moter stuck you could try putting the car in gear and rocking it,but to be honest i dont see how this could have happened while you driving.
whats your location? as someone near to you might be able to help.
Perhaps a battery lead's off, taking out both ecu and starter. :?
Broken engine earth, causing dead battery and inability to run starter/coil?
HimBigChief
Post by HimBigChief »
Hit a pot hole in the road and tripped the emergency cut-off valve?
Image Image
I haven't got one but I thought they didn't stop the starter motor spinning :?
steve_earwig wrote:I haven't got one but I thought they didn't stop the starter motor spinning :?
Isolates the fuel pump doesn't it?
maglite1
Post by maglite1 »
try tapping on starter solenoid with jack handle or simmilar bar possibly the solenoid stuck , do the dash lights go dim or flicker when ya turn the key ? put ignition on and flick main beam to test if battery is ok , lock the car and un lock it a few times from passanger side front doorincase immobiliser has kicked in , from the clicking you describe sounds like starter jammed or battery problem , good luck .
junction 7 m62 st helens wa9 4bd
HimBigChief
Alternatively, maybe the engine just siezed. That would explain it stopping instantly and then just clicking when trying to turn it over. Can you get a socket/spanner on the cam or crank bolt and turn it manually? Have you tried jumping it from another car? What's the voltage reading across the battery terminals (you'll need a multimeter for this)?
Image Image
