hard to start , fuel system leak.
Posted: Fri Sep 24, 2010 1:49 pm
hello again everyone , following recent engine re build the car is running sweet but yesterday when i went to go out in the car and today it struggled to start and turned over a good few times before it fired up , this only happenes when the car has been layed up overnight and once its been run it starts instantly , i just went to go out and again it turned over a good few times before it fired up so i opened bonnet and noticed a fuel leak on the pipes going to the injector rail .
on the top of the coil packs there are 2 fuel pipes that come from bulkhead and sit on top of coil packs with little cover over them they go to the injector rail , one of the pipes has a small white right angle with about 2 inches of pipe from the right angle then into the injector rail , the leak is on the pipe where it connects to the right angle it has 2 crimped wire clips , im thinking of going to halfords and getting 2 jubilee clips to stop the leak .
question is , when the car is layed up over night and the fuel system is loosing its pressure through this leak would it then make the car hard to start as it has to pull fuel through again , once its running say i go shopping and come back hour or so later it fires up perfectly , im not loosing any water and the tempriture is sitting stable just above 70% to 80% on a run , anyway off to halfords for some jubilee clips see if it sorts problem , thanks alan.
