2.1td fuel pump question
totaleclipse
Post by totaleclipse »
On the side of the pump (towards the front of the car) there is a large 32mm nut.
Recently my car had become hard to start and sore on fuel, but runs great when you get it going, anyways i just went outside to move it and noticed a big pool of diesel where it was parked, so i started up the engine and popped the bonnet to notice a steady stream of diesel pouring from this nut, which was very loose.
I tightened the nut, and turned the key and it burst into life VERY quickly, where it had been needed cranked and cranked for the last week or so and no more outpouring of diesel.
my question is, have i cured the problem or has something else caused this to happen that will make it come back.
cars a 1997 2.1Td executive with the lucas pump.
1997 2.1TD executive estate - mmmm, lovely :)
poddack
Re: 2.1td fuel pump question
Post by poddack »
Sounds like you've cured it, loose nut, fuel pouring out = air getting in and hard to start!
Hmmmm, straight 6 goodness!
totaleclipse
poddack wrote:Sounds like you've cured it, loose nut, fuel pouring out = air getting in and hard to start!
heres hoping, just a bit curious why it would come loose in the 1st place.
swiss
Post by swiss »
Confucius say, keep an eye on it
The man with no car
totaleclipse
still seems to be ok, and the cars running noticeably better than it has for a while now.
