406 HDi not terribly interested in starting - any ideas?!
Posted: Tue Oct 05, 2010 5:27 pm
Hi there,
Apologies if this is deemed to be in the wrong topic area but it's a bit of a broad problem.
I've not long become the owner of a Pug 406 HDi - Economic and less holes than the Alfa 75 it replaces...that'll do, or so I thought!
Having only ever started straight on the key when I bought it, cranking it for 30 secs+ seemed the norm for the 1/2 dozen journeys I've done in it...a problem ignored is a problem solved, especially with a big battery...
Anyhow, on my way home from Banbury to Swansea it began conking out on the exits of roundabouts, though not always, turning left rejoining carriageways, and after being left for a while it would eventually show signs of life after prolonged cranking periods until I reached Hirwaun.
The fault codes which initially appeared were, using a Mac tools reader,
P0230 - fuel pump relay circuit malfunction.
P0220 - throttle position sensor malfunction (Switch B)
P0120 - throttle position sensor malfunction (Switch A)
P00CCpd - Not in database.
P00C8 - Not in database.
The latter two wont clear. The rest don't re-appear, though this may be because it's not started again.
I was baptised with petrol as opposed to holy water and embarrassingly Diesel systems are a bit of a mystery - Fuel pump makes a noise and sounds like it's pressuring, plenty in the filter bowl, no obvious corroded electrical connections.
The only strange thing is that I can only measure a fixed resistance at the throttle pot which would indicate that it is f*cked, but a local specialist (Which I'm trying to avoid paying) says that it should start despite this apparent fault so...
Any ideas?!
Any ideas?!
