2.1td changing glow plugs
Posted: Thu Oct 07, 2010 10:34 pm
by jim
hi all, new to this forum, could do with some words of wisdom. got a 1997 2.1tdi 140k now the mornings are getting colder its taking longer and longer to start, im assuming its the glow plugs, just wondering if theres a good method for changing them as the left two look really well buried, any help is much appreciated,jim
Re: 2.1td changing glow plugs
Posted: Fri Oct 08, 2010 3:51 pm
by swiss
Have you had a look in the Haynes manual? It does cover the 2.1. I know when I did the plugs in my 1.9 I had to rip out chunks of air duct to get at them, and the NDE one was buried right behind the fuel pump. I got the world's smallest engineer to try it but even her tiny, child-like hands could do nothing but drop a spanner behind the alternator >.<
Posted: Fri Oct 08, 2010 4:35 pm
by omega
hi ive gotr a 2.1 that im stripping at the moment
i think if you remove the air filter you will be able to get to them but be careful as they will be tight.
Posted: Sat Oct 09, 2010 8:20 am
by jim
thanks guys, will give it a go later
Posted: Mon Oct 11, 2010 9:50 pm
by totaleclipse
i changed the glow plugs on my 2.1a while back.
done 3 and left the one behind the fuel pump, which already looked a lot older than the other 3, lol.
moral of the story is, save some cash and buy 3 instead of 4.
Posted: Mon Oct 25, 2010 6:01 pm
by jim
right, changed the plugs yeterday, not as hard as people were saying but still abit fiddly, managed to change all four, used a standard 8 and 12 mm spanner, took about an hour all in all, did have to remove the air intake and engine cover
Posted: Tue Oct 26, 2010 9:29 pm
by poddack
did it work?
