pug 406 1996 petrol 1.8, fuel pump not priming
boris
Post by boris »
Hi there
I have been having a problem with the car not starting intermittently,
changed fuel pump, worked for a day, now will not prime, however, when connected direct to battery, pump works,
at a loss, apart from the multi relay next to the ECU or the ECU itself or inertia switch, does anybody have any ideas what could be causing this?
Thanks Steve
