Lower engine mount
adam03031980
Lower engine mount
Post by adam03031980 »
My lower engine mount is looking iffy again but what i want to know is are they an MOT failure if theyre damaged or split
jasper5
Re: Lower engine mount
Post by jasper5 »
A broken lower mount is NOT an mot failure, but you may get an advisory.
It isn't a testable item.
http://www.motinfo.gov.uk/htdocs/index.htm
yup iagree:
its not a fail but you do get an Advisory,
Mines been packed with windscreen sealant Altho the mot inspector says its a very neat & tidy bodge he carnt just leave it unmentioned and had to put it down as an Advisory,
iwouidnt worry about it unless there alot of Excess movement in the mount , :P
adam03031980 wrote:My lower engine mount is looking iffy again but what i want to know is are they an MOT failure if theyre damaged or split
do you get any judder in 1st gear setting off with that bottom mount naff ?
adam03031980
My car has been juddery in 1st gear for the last 90k miles not sure why whether its the mount or clutch but have stopped worrying about it, its a pity you cannot buy those 2 part polyurethene mounts that slide in either side like some of the other pugs theyre probably too hard though
Mines a bit juddery in 1st it dosent do it all the time tho,
been told its down to the top mount the one on the gearbox imight have a bash at changing it this week if ican get a new one,
ithought it was the d.m.f failing at 1st but im glad its just the mount 8)
ye i have a judder in 1st gear , on a new clutch 8 month later,
i put it down to a broken spring on the clutch but i think it could be a mount , may get them changed soon
