Hi,
I have just had my Pug 2.0 110bhp serviced (new filters, oil etc), I have filled the tank and added some diesel injector cleaner.
The problem is that my dad was following my back home; he noticed it producing black smoke only when I accelerated (This was at motorway speeds, not low speeds around town), does anybody have any ideas why?
Peugeot accessed the ECU and found no faults, is it that the turbo is not producing enough pressure so there is some un-burnt diesel leaving the exhaust? (If so how do I fix it?)
Many thanks for any help,
Andy
Your expert advice!
- xplosiv
- xplosiv
There is only really one answer..........
EGR Valve, located to the left at the back and at the top of the engine near the bulkhead looks like a diaphram valve with a black rubber tube connected to it.
If this looks all sooty and you can smell exhaust fumes around it when the engine is running then it is leaking and it does cause the smoke from the zorst.
looks like this http://groups.msn.com/honestjohn/proble ... hotoID=164
- Captain Jack
- xplosiv
