I'm after a basic code reader for my year 2000 H.D.I.
I believe the E.C.U. connection to be under the bonnet although ive not had time to hunt this down,nothing in a haynes manual,no surprise there.
Anyone ???
Code reader
Re: Code reader
Basic code readers don't seem to work very well, if at all, on HDi's. Only certain solution is Peugeot's own Lexia / Peugeot Planet 2000 interface. (Chinese clone about £150 on eBay, search for 'Lexia 3').
The diagnostic connector is behind a pop-out cover next to the headlight height adjuster control.
Re: Code reader
Thanks mate,i'll take a look for one,i don't suppose theres an easy fix to put out the engine management light ??? there is nothing wrong with the car now so i just need the fault clearing/light out.dogslife wrote:Basic code readers don't seem to work very well, if at all, on HDi's. Only certain solution is Peugeot's own Lexia / Peugeot Planet 2000 interface. (Chinese clone about £150 on eBay, search for 'Lexia 3').
I read on a post here that it would cancel/reset after a half a dozen cycles of the ignition but this has not happened but could on some as nobody disagreed.
Re: Code reader
If the fault is clear, the EML may go out after several fault-free, 'journeys'. You have to have the engine running for some minutes without a problem, a few times over.....
Re: Code reader
The car runs perfect in every respect but its been on a few weeks now,at first i thought it would clear but no luck.dogslife wrote:If the fault is clear, the EML may go out after several fault-free, 'journeys'. You have to have the engine running for some minutes without a problem, a few times over.....
Re: Code reader
i'll find a link to the sort of reader i use.
Current car - Ph3 1.8 306
