Fury556
Posts: 18 Joined: Wed May 05, 2010 2:50 pm
Post
by Fury556 » Mon Feb 07, 2011 10:45 am
Hi all,
I've had a quick search but not sure if it could be the same issue.
Basically after changing my Aux belt the car has started making a clicking noise with engine speed. It's almost inaudible at idle but gets noticably louder around 2k onwards. The only way I can describe the noise is like someone has put spokey-dokes on the crank
Could this be the crank pulley on it's way out?
Peugeot 406 1998 2.1TD
Posts: 19813 Joined: Thu Oct 04, 2007 6:09 pm
Post
by steve_earwig » Mon Feb 07, 2011 11:23 am
I think the 2.1 has a solid pulley. Take the aux belt off again and run it without, it could be a whole host of things but it's most likely to be something to do with the aux belt, perhaps the idler's had it. Or it could be your cam belt starting to shred
poddack
Posts: 382 Joined: Mon Jul 14, 2008 10:33 pm
Post
by poddack » Mon Feb 07, 2011 2:00 pm
from experience I would DEFINATELY check the idler and tensioner, there will be tears otherwise.
Hmmmm, straight 6 goodness!
Fury556
Post
by Fury556 » Mon Feb 07, 2011 2:09 pm
I remember looking at the cam belt and couldn't see any signs of cracking etc.
I'll have a look asap at the other bits, thanks
Posts: 5315 Joined: Sun Mar 28, 2010 9:56 pm
Post
by Gary406 » Mon Feb 07, 2011 2:10 pm
ye sounds like tensioner pulley ...
i changed my belt other month . then 2 month later it cost me another £150 to get the tensioner idler pully changed cos that went.
inspect the belt with car running on tick over.. you should be able to see the idler pulley , check the belt is running nice and smooth round it..
if its that expect to pay £150+ for the job done, unless you can do it yourself will cost you about £70
it isnt an easy job either...
Fury556
Post
by Fury556 » Mon Feb 07, 2011 4:48 pm
I'll check the belt to see whether it's too tight as that may cause an issue.
My old mans a pretty solid mechanic so we should be able to sort it out ourselves - I refuse to pay garages unless I absolutely have to!
