406 turbo misfire
Posted: Wed Feb 09, 2011 5:42 pm
by craigtd
hi, can anyone help me ?, i have a 406 2.0 turbo petrol, the boost is turned up but not alot but under hard exceleration it somtimes misfires,it also does this when you go to pull away somtimes and when you sit at a speed, but it will tick over fine and runs fine apart from this, any help would be great
Re: 406 turbo misfire
Posted: Wed Feb 09, 2011 8:38 pm
by carlb
i would think plugs or possibly coil
carl
Posted: Wed Feb 09, 2011 9:36 pm
by craigtd
would that not make it misfire all the time ????
Posted: Wed Feb 09, 2011 9:42 pm
by Gary406
does it still miss with the boost turned back down to normal ?
Posted: Wed Feb 09, 2011 9:48 pm
by craigtd
yes,
Posted: Wed Feb 09, 2011 9:50 pm
by craigtd
i did read somewhere that when you turn the boost up it can blow the spark out,?????? not sure how true this is.
Posted: Wed Feb 09, 2011 10:05 pm
by carlb
hi no it is normal when plugs are worn and the gap is too large it will take more energy to cross the gap it also puts a very large strain on the coil or coils also the coils can break down internaly and produce a weak spark that may be ok on idle and steady driving but with boost it cant cope as it takes far more energy to cross the gap
Posted: Wed Feb 09, 2011 10:11 pm
by craigtd
any idears on a good make of plug for turbo'd 406's
Posted: Wed Feb 09, 2011 10:37 pm
by carlb
hi i would use ngk`s bkr6ez i think but im not sure of that number
Posted: Thu Feb 10, 2011 8:25 am
by Gary406
NGKs - Bosch -
personally i would go for the bosch super 4s
what about leads ?
http://cgi.ebay.co.uk/Peugeot-406-2-0i- ... 5ad84e621f
