306 gti6 manifolds
- jameslxdt
306 gti6 manifolds
i know that the gti6 exhaust manifold can be fitted to the 2.0 16v to gain alot of power, i was just wondering if the inlet manifold would fit and if there would be any gain in power from doing so
- 1.6 8v
Yes it will fit, Not sure what the sensors are like on the 1.8 but I've changed the sensors to the GTi6 inlet from a 306 S16 I have, Had to make a couple of plates as it uses a external idle Valve against the 6's stepper motor idle valve and new throttle cable and that's it, The throttle body is a good 15mm larger so you should notice a differance
- Foxy
- Forum Admin<BR>Know it all
No, it wont be compatible. The S16 uses the same fuel rail as the GTi6 so its mostly ok. The 2.0 uses totally different managment and a different fuel rail.
However the exhaust manifold if something you should look into, its a straight swap over and its a 4 branch tubular 4-2-1 so you will see 10+bhp and much more responsivness. You will need a GTi6 (or 205 1.9 GTi) cat though as the 2.0 isnt the same.
Used to own the finest 406 in the UK - RIP
- 1.6 8v
