406 glx 2.0 exhaust blow problem
Posted: Sun Feb 20, 2011 1:17 am
by mdutton25
i have got a 406 glx 2.0 and the exhaust is blowing i have checked the exhaust under the car as it sounds like its blowing around the centre box so i tuck the exhaust off from the cat and checked it and the exhaust is in mint condiction and there is no hole or cracks. so put back together and still blowing so i am stuck at where to check next..................
Re: 406 glx 2.0 exhaust blow problem
Posted: Sun Feb 20, 2011 7:31 am
by teamster1975
Welcome to the club!
I reckon this is the flexible joint where the pipe joins the manifold; you've got a couple of bolts that pass through springs and the springs get tired over time. You can bodge it by putting some washers behind the bolt head (I've done this) or get a replacement kit from a factors for around £12.
Posted: Sun Feb 20, 2011 8:49 am
Get someone to try blocking the end of the exhaust with a wad of rag, it should exaggerate any blow and make it easier to spot.
Posted: Sun Feb 20, 2011 8:52 am
by mdutton25
cheer guys will try it today
Posted: Sun Feb 20, 2011 12:37 pm
by mdutton25
na thats sound the flexi pipe is seems like its blowing from the joints
Posted: Sun Feb 20, 2011 3:45 pm
by mdutton25
checked that and no joy what else do u think i should try?
Posted: Sun Feb 20, 2011 3:51 pm
Reassemble with exhaust paste?
re: 406 glx 2.0 exhaust blow problem
Posted: Sun Feb 20, 2011 5:12 pm
by Gary406
i always use holts firegum when changing exhaust parts
cheap and bloody good stuff
