Page 1 of 2
406 2.0 HDi - Leftover plug and pipe for HG change.
Posted: Tue Feb 22, 2011 11:37 pm
by ChazJ
Hi,
Just like to pick all your brains please!
After recently doing a head gasket change with my Dad on his 406 HDi and leaving him to put the last few bits on and back together, we are left with only 2 odd bits.
We are left with a washer type hose coming from the back of the bulkhead, looks like it may go down towards the back of the engine - as a guess, is it for the turbo actuator?
And one plug at the front of the engine, near the radiator - it's part of the main loom, whether this helps of not?
I will take some pics tomorrow to show the problem bits, but I thought I'd get my topic up and running first after stumbling across this helpful site!
Chaz
Re: 406 2.0 HDi - Leftover plug and pipe for HG change.
Posted: Tue Feb 22, 2011 11:51 pm
Hi there!
Umm, the pipe probably is for the turbo, there should be one coming from one of the vacuum solenoids on the bulkhead.
Does the plug look like this:
It's just hanging loose on mine, I think it's for the water in fuel detector which mine lacks.
Posted: Wed Feb 23, 2011 8:22 am
by moodybluetwo
On my car that wire goes to the fuel rail pressure sensor....the yellow plug normally clips to that broken plastic clip just up to the right.
Posted: Wed Feb 23, 2011 9:32 am
It's not connected to anything on mine, it was just dangling until I cable-tied it to the remains of said clip
Posted: Wed Feb 23, 2011 11:19 am
by moodybluetwo
Having looked at Autodata the fuel pressure sensor shows three wires...so it may be something else. On my car 2.0HDi it was the sensor and because it was loose it kept cutting the engine out. If it was dry out side I`d have a look...but its raining . What problem is it causing?
Posted: Wed Feb 23, 2011 5:48 pm
by ChazJ
Hi,
Thanks for your prompt and helpful replies.
Here are the offending articles!
It's the pipe coming from the bulkhead and I've got it laying over near the oil cap - just for ease or visibility.
The yellow plug with extension on, ending up with a red plug - front of engine, coming off of loom... and yes, the oil filter will be changed
Thanks!
Posted: Thu Feb 24, 2011 7:49 pm
by martint
mate did u get it all sorted cos i read that last one & it didnt make sense to me.mind you-ive had a smoke.haha
Posted: Thu Feb 24, 2011 8:37 pm
by jamjar1383
the pipe looks like its for eather the turbo actuator or the egr valve, and i think the red plug is for the filter housing on the bottom of it.
Posted: Thu Feb 24, 2011 9:04 pm
by Gary406
Posted: Thu Feb 24, 2011 9:08 pm
by lozz
martint wrote:mate did u get it all sorted cos i read that last one & it didnt make sense to me.mind you-ive had a smoke.haha
http://www.youtube.com/watch?v=dd37S8uJNO8
Posted: Thu Feb 24, 2011 9:19 pm
by Gary406
Posted: Thu Feb 24, 2011 9:34 pm
by ChazJ
I've not had time to look at it yet, but will at the weekend.
I don't quite understand what didn't make sense.
Above each picture was a description of the article I need help with..
But then again, maybe the 'smoke' does things to your mind that normal people can comprehend.
Cheers.
Posted: Thu Feb 24, 2011 9:43 pm
by lozz
ChazJ wrote:I've not had time to look at it yet, but will at the weekend.
Cheers.
its just a bit a Banter mate:
Re: the smoke yeh very true mate,
it can cause Blured vision /paranoia, and obesity as per the munchies
Posted: Thu Feb 24, 2011 9:46 pm
The Sony Corporation of Greed and hypocrisy wrote:This video contains content from Sony Music Entertainment, who has blocked it in your country on copyright grounds.
Sorry about that.
I'm getting so sick of seeing that these days
Posted: Thu Feb 24, 2011 9:51 pm
by lozz
Sorry about that.
ah yep it is a bit anoying
heres the original,
http://www.youtube.com/watch?v=k2pXxHW1DHs
