Im going to change the lower engine mount,
but im thinking of just popping the drive shaft out of the gearbox end and leaving the other side in the hub,
as anyone else changed em this way is it possible ?
You have to remove the whole driveshaft as the driveshaft has a bearing on it that goes through a bearing carrier and is bolted into the carrier.
The bearing carrier is the housing for the engine mounting as well.
Gary, I'm still waiting to hear about borrowing a ramp for sunday, my daughter must be on funny shifts....I will let you know whether I have it or whether you can come to my house...either way I will look at it on sunday for you.
jasper5 wrote:You have to remove the whole driveshaft as the driveshaft has a bearing on it that goes through a bearing carrier and is bolted into the carrier.
ar rite cheers mate,
iwill have to buy a big socket as ive only got a 35mm one hence the reason of thinkin of leaving shaft in hub,
imight as well change cv gaiters while im at it,
cheers mate really apreciate it.
Right....got the workshop for sunday, it's in Rawtenstall...is that alright?
If that's ok I will PM the address and post code if you are using sat nav.
Replaced my lower mount lastnight, its made a HUGE difference! No judders on startup, gear changes are alot nicer and I can give it a proper cain up through the gears now without having to compensate for the judders with the clutch
Its too late to be of help to you guys but it is possible to to remove to engine mount bracket with the driveshaft in situ.
From memory it was a pig to fiddle off the sub frame but a whole lot easier than taking out the drive shaft,
99 HDi Estate 110 fast approaching 200K. edit: now 215K
