wierd fault
Posted: Thu Mar 03, 2011 5:07 am
by andymacg
hey up folks
got a weird fault thats just started happening on my 1.8 16v, every now and then as soon as you select reverse ,the engine, splutters then it just cuts out, unless you keep the revs above 2500, doesnt do it all the time just now and then andit doesnt do it any of the forward gears
makes for interesting reversing when it happens.
any ideas whats up ?
Re: wierd fault
Posted: Thu Mar 03, 2011 6:29 am
Is this when you shove it in gear but before you lift the clutch or anything? What happens if you disconnect the reversing light switch?
Re: wierd fault
Posted: Thu Mar 03, 2011 11:00 am
by mjb
Manual or automatic?
Re: wierd fault
Posted: Thu Mar 03, 2011 2:14 pm
by andymacg
it s a manual , it happens as soon as you move the gear lever to the reverse position,i shall check the reversing light switch at the weekend just an wierd thing as it doesnt do it all the time
Re: wierd fault
Posted: Thu Mar 03, 2011 3:25 pm
You might have to leave it disconnected to give the fault time to happen.
I can't imagine how the brake light circuit would affect the engine running, unless the wires are munched somewhere. Oooh, while the air filter's off check out the wiring you can see under there.
Re: wierd fault
Posted: Fri Mar 04, 2011 12:00 pm
by andymacg
woohoo fixed it had a look this morning was quite easily one of the most simple things ever.it
was one of the wires off the reset button under the bonnet ,the insulation had wore through and was hitting the inner wing in reverse , a bit of i nsulation tape and its cured
dont you just love easy fixes
Re: wierd fault
Posted: Fri Mar 04, 2011 2:31 pm
by mjb
Lucky! I can see that being nearly impossible to find if it weren't obvious!
