fault codes
Posted: Tue Mar 08, 2011 8:50 pm
by john170277
just broke down rac came out and did diagnostic check it came up with low fuel presure ,what could be causing this
2.0hdi 2002 110bhp
Re: fault codes
Posted: Tue Mar 08, 2011 9:02 pm
by Gary406
could be lift pump in the fuel tank.
expensive repair if it is :shock:
Re: fault codes
Posted: Tue Mar 08, 2011 9:14 pm
Not so expensive, not as bad as com2000 for a start.
Re: fault codes
Posted: Tue Mar 08, 2011 11:19 pm
by Doggy
About £65 from Euro Car Parts, last time I looked
Re: fault codes
Posted: Wed Mar 09, 2011 8:27 am
by Gary406
oh right :oops: why was i under the impression that was an expensive fix :oops:
Re: fault codes
Posted: Wed Mar 09, 2011 1:01 pm
by Doggy
Anything's an expensive fix if you let Pug near it. :roll:
Re: fault codes
Posted: Wed Mar 09, 2011 5:44 pm
by john170277
2 fault codes that came up were p1138 p1112 if that helps
Re: fault codes
Posted: Wed Mar 09, 2011 7:04 pm
Google says possibly fuel pressure regulator but I'm still betting on the pump - can you hear it run when you turn the the "ignition" on?
Re: fault codes
Posted: Wed Mar 09, 2011 7:12 pm
by john170277
yes can hear pump car is fine on tick over but when moving its a bugger
what is fitting time for a lift pump
Re: fault codes
Posted: Thu Mar 10, 2011 8:30 am
by Doggy
You ca do it yourself in half an hour, if the locking ring comes undone without a battle. If it doesn't, you've lost nowt trying.
Re: fault codes
Posted: Thu Mar 10, 2011 9:23 am
Ah, I was thinking the car was dead after having to be recovered by the rac, they usually are if the lift pump goes, but if the car's actually running I don't think it's that after all. Back to the fuel pressure regulator?
Re: fault codes
Posted: Fri Mar 11, 2011 5:11 pm
by john170277
need help!car came back from garage today they will not touch it saying its not cost effective the 2 faults that are on system are fuel pressure regulator and fuel rail pressure are these 2 related and can it fixed for under 300 quid
i would be greatful for any advice
you cazn contact me if needed 07850914510 07539231551
cheers john
Re: fault codes
Posted: Fri Mar 11, 2011 5:39 pm
by jasper5
john170277 wrote:need help!car came back from garage today they will not touch it saying its not cost effective the 2 faults that are on system are fuel pressure regulator and fuel rail pressure are these 2 related and can it fixed for under 300 quid
cheers john
You might find this interesting reading......http://www.ilexa.co.uk/forum/index.php/ ... 803.0.html
Re: fault codes
Posted: Sat Mar 12, 2011 5:09 pm
by john170277
today i unpluged the top plug from the fuel pressure reg and everything is fine no limp home and no eml
does that mean the problemlis with the fuel pressure reg
