I was even going to post up here how it seemed to make the car a bit better on the throttle!
This morning though the Check Engine Light came on with a loss of power
The two things may not be connected, but any advice please ?
Well, after all that the problem appears to be the Radiator cooling fan itself!I wrote:
- P1404 - ECU fault / Glow Plug Control Module/Relay
P1403 - Engine Coolant Heater (radiator fan !) Wiring fault/Fan Relay/ECU fault
P1408 - Engine Coolant Heater (rad fan) Control - Wiring/ECU fault/Battery
P0221 - Throttle Potentiometer (this could be an old code because this was changed last may at a Peugeot Dealer (famous for forgetting to reset the codes)
