Page 1 of 3
Oil temp
Posted: Tue Apr 12, 2011 7:56 am
by uoapsdb
406 hdi 110 W reg - are there any known probs with the oil cooling on these 406's. On a trip to France last year (admittedly climbing mountain roads) the oil temp got close to the 140 mark and the STOP warning light came on, though other cars managed ok. Again, driving about 60 miles to Gatwick last week, carrying 5 people + luggage the temp rose sharply again though I was able to keep it just around 130 by coasting. Water temp is fine. Does the oil cooler get blocked ? Can the system be flushed ? Could it be an oil pump probelm ? Any suggestions welcome, particularly if there is a known issue.
Re: Oil temp
Posted: Tue Apr 12, 2011 12:53 pm
by Doggy
The oil cooler is a small oil/water heat exchanger, mounted immediately behind the oil filter. Not heard of problems with them, other than I think someone had a leaky one, last year or thereabouts....
I guess it would be fairly easy to prove the water passages are blocked or otherwise, albeit having to drain the cooling system to do so. Don't know how you'd go about proving the oil passages are clear. I've no idea what they cost as I can't access ServiceBox from work.
Are you sure the STOP light is due to oil temperature? It can be other things, (water temperture, brakes/ABS, oil pressure).
Re: Oil temp
Posted: Tue Apr 12, 2011 1:38 pm
by uoapsdb
Thanks for your thoughts dogslife. yes I'm sure it was the oil temperature - when the guage got just below the 140 mark the STOP light came on, when we sped up again going downhill with less load on the engine the gauge moved away from the 140 mark the STOP light went off, the water temp was slightly above normal but not high at all.
There is a seperate small radiator to the right of the main rad (looking from the front), is that not to do with cooling the oil ?
Noone has responded with a known problem so maybe there isn't one.
It's not just the STOP light coming on that concerns me, it's the way the oil temp climbed so much, even on a short jouney about 60 miles when fully loaded. Have any owners seen their oil temp approach the 140 mark when fully loaded or driving up long big hills ? These were big hills - they're called the Alps.
Re: Oil temp
Posted: Tue Apr 12, 2011 1:47 pm
by bytecode
Hi,
have you checked your oil level?
have you since done an oil change?
You can get a "flushing additive" in a can that you add "x minutes" before doing the oil change - this helps remove any crud (although if you've had a leaky seal in the past that's blocked with crud , it can clean that too are your seal will resume leaking).
I had high oil temps on my MGF when I was running out of oil - hence asking about the oil level.
High temps. degrade the efficacy of oil too - so I'd definitely change the oil and filter ASAP if you haven't already...
Re: Oil temp
Posted: Tue Apr 12, 2011 1:57 pm
uoapsdb wrote:There is a seperate small radiator to the right of the main rad (looking from the front), is that not to do with cooling the oil ?
That's the intercooler.
That's a weird one and no mistake
I reckon what the other guys say - check the oil level (what did you put in last btw?) and treat as for overheating. Other than that, call in a witch doctor?
Btw how noisy are your injectors? It's probably wide of the mark given that diesels run on pre-ignition but perhaps if the pre-injection is really bad it might cause heat problems (anyone?)
Re: Oil temp
Posted: Tue Apr 12, 2011 2:59 pm
by hammerman
My oil temp climbs towards 140 when towing(including the alps,St Gotthard & Mt Blanc tunnels in august)but i`ve never had the stop light on for oil temp.I have for water temp,when it went off the end of the scale
It normally sits around the 110 mark,but the gauge is a bit difficult to work out due to the increment lines
But when towing it sits around 120-130 ish.
It could be a dodgy sensor,which i think is next to the oil filter.Mine played up last year,telling me i had no oil pressure.
I take the oil temp reading with a pinch of salt.Only my previous Xantia had a oil temp gauge.All my other cars did`nt.So there was no need to worry about the temp.
Re: Oil temp
Posted: Tue Apr 12, 2011 3:04 pm
by DiscoPol
I think the first port of call would be an oil and filter change and possibly a cooling flush and change too, then we can really start hypothesizing about oil ways and so on.
By the way the Alps are seriously big hills
Re: Oil temp
Posted: Tue Apr 12, 2011 5:01 pm
by uoapsdb
Thanks everyone for your ideas.
I've just checked the oil level and it's fine - slightly below max.
The car has had an oil and filter change less than 1000 miles ago.
The water coolant system was flushed about 6 months ago.
I use a local garage for servicing and repairs and only go to Peugeot for diagnostic purposes as a rule.
I've been resisiting going to Peugeot for this problem,
I've found this forum has answers based on experience rather than guesswork like Peugeot.
One example was the 'Brake fluid level is Low' warning which Peugeot
were going to charge me £150 to replace the reservoir for
(which had nothing to do with the problem). However, an article on this
website showed that it was a known issue and due to the switch below the handbrake.
I followed this article and fixed the problem for free !!
Sounds like this oil temp rise isn't a known issue though.
Re: Oil temp
Posted: Tue Apr 12, 2011 5:40 pm
by Doggy
Like most owners, (I suspect), I don't pay much attention to the oil temp. but have noticed that in warm weather it can drop as low as just over 90 if going really slowly and as high as 130 ish if driven quickly - and this without towing anything / being heavily loaded or dealing with 'continental' temperatures.
Unlike the water temp., which is regulated by the thermostat, fans etc., there is nothing to 'control' the oil temp. therefore it's not surprising it mirrors how hard the engine's working. Worth checking all the above suggestions, but it may turn out to be 'normal' given the fairly extreme set of conditions you describe.
Re: Oil temp
Posted: Tue Jan 07, 2014 7:33 pm
by uoapsdb
Resurrecting this question as I never got to the bottom of the problem and really want to take the car to France. I still have the problem of the oil temp guage (left hand one) going v high when I carry a heavy load or drive at high speed for a lengthy time say 70 for half an hour.
Any suggestions welcome - flush / replace oil cooler ? could the oil pump be weak ? fit an extra oil cooler ?
One thing that someone mentioned above was to do with the injectors - they have always leaked a little bit of oil but not enough to merit working on them.
I believe the car had been unused for a period - say a year when I boought it about 5 years ago.
Any advice welcome please
Re: Oil temp
Posted: Tue Jan 07, 2014 8:00 pm
by rwb
I guess over the last couple of years you've kept an eye on it and have a better idea of what's normal?
Any chance you can get it on Peugeot Planet? Where abouts are you? (There are a lot more about than there were in 2011.)
Re: Oil temp
Posted: Tue Jan 07, 2014 9:09 pm
by Bailes1992
I'd try get a new or even a salvage oil cooler.
I'd replace the coolant. I use Mocal Inugel which I recommend highly!
A good quality 5w40 fully synth oil with an OEM spec filter.
Also have a good look at your radiator! The stop light only comes on with the coolant so that must be overheating too!
If you're willing to spend a little then a Mocal aftermarket oil cooler might benefit you!
Re: Oil temp
Posted: Tue Jan 07, 2014 9:57 pm
by mjb
Shame FLIR cameras aren't cheap... could probably help pinpoint the problem in seconds on a rolling road using one
Re: Oil temp
Posted: Wed Jan 08, 2014 11:56 am
by Rolebama
It might be worth checking the temp of the oil in another way, as it could be a faulty sensor or gauge. I would try (very gingerly) to feel the sump when the STOP light has come on. I know of many a water temp sensor that has failed, and electric oil pressure switches and sensors.
Re: Oil temp
Posted: Wed Jan 08, 2014 12:49 pm
by benczuk
