£2.25 SUMP WASHER!
Posted: Thu Apr 14, 2011 12:56 pm
by panadero
My local stealer has just quoted me £2.25 incl VAT for ONE 14 mm copper washer. Is this a record?
So I decided instead to buy a bulk set (140 pcs) of washers off ebay. This includes 15x14mm washers suitable for
406 sump plug. 15 would cost £33.75 at current stealer prices. At this rate in a
couple of years the stealer price for one washer will be up to the £3 level. For members' information,
panadero
Re: £2.25 SUMP WASHER!
Posted: Thu Apr 14, 2011 2:14 pm
That's funny, I changed the sump washer on mine 2 days ago and that was the first time I've ever changed one (I've never had one leak, before you ask), err, it was free from my mate in the car spares shop :?
I think it was 16mm...
Posted: Thu Apr 14, 2011 2:17 pm
by teamster1975
I don't think I've ever bothered either. Quick flash in the blow lamp to anneal it and job done!
Posted: Thu Apr 14, 2011 7:49 pm
by Gary406
i dont think normal washers will do the job to be honest.
the standard copper waser is about 3mm thick and it squashes to about 1mm as you bolt the sump bolt tight, a standard steel washer will not squash when you tighten it. so i think a standard steel washer may leak oil past it becuse the copper washer squashing inbetween makes the seal air tight. :?
i could be wrong tho,
Posted: Sat Apr 16, 2011 11:19 am
by panadero
the copper washers i got are 1.5 mm thickness which is i believe is about standard for the oil sump plug.
Posted: Sat Apr 16, 2011 11:29 am
It can't be steel 'cos it's got to have some give to it, and not rubber I guess as this would either go hard or squeeze out. The real thing is round in section, squeezing flat as mentioned.
And there I was looking at this thing thinking about how much money I could have saved on a wedding ring - "It's red gold dear, very unusual and expensive" :supafrisk:
Posted: Sat Apr 16, 2011 11:30 am
by Gary406
you got a link for those mate, i will get some for my next services.
Posted: Sat Apr 16, 2011 1:10 pm
by teamster1975
The last filter I bought was from the stealer, it came with a new sump washer. £8 from memory?
