Anyone faulty speedo- mines fixed! Read!!
Posted: Fri Apr 15, 2011 10:54 pm
by martint
Aftet 4 weeks of going round the bend with my speedo flickering down to zero-finally renewed the speed sensor on gearbox and hey-presto!!!just thought i'd give it a mention as its supposedly a common cheap nasty part that will eventually fail. And here was i taking out & soldering joints in the clocks etc.Ah Well
Re: Anyone faulty speedo- mines fixed! Read!!
Posted: Sat Apr 16, 2011 12:41 am
by wasp
martint wrote:Aftet 4 weeks of going round the bend with my speedo flickering down to zero-finally renewed the speed sensor on gearbox and hey-presto!!!just thought i'd give it a mention as its supposedly a common cheap nasty part that will eventually fail. And here was i taking out & soldering joints in the clocks etc.Ah Well
Hi
Ive had the same problem a couple of years back, yep that white? cheap looking plastic drive thingy,if i remember right when i looked in service box theres an alternative drive which has metal gears as opposed to platic ones- called 'TAXI' type!!1 me thinks peugeot also knows the standard ones ( which i had fitted) are shite :shock:
Posted: Tue May 10, 2011 9:41 pm
by andymccabe13
where abouts is this found on a 1.9 td p reg?
